Originally Posted by lostsurferinbc
I have the mark on the crank pulley lined up with 10 tdc
Wait, you have it set at 10? BTDC while installing the distributor? When installing the dizzy, you're timing marks should be set at 0?, with the engine at TDC on the compression stroke. When you set your ignition timing, you will then rotate the dizzy until you're firing at 10? BTDC.
As FRISBEE said, don't forget to put the jumper wire in when you set the ignition timing
