Since it cuts out when the engine gets warm I'm more inclined to believe you may have a problem with your igniter. You should check to see if you're getting spark next time it cuts out with an inline spark tester.
This could also explain why it fires once the engine has cooled down, since several times faulty igniters start having issues in extreme temps (hot or cold)
