Originally Posted by btwilson86
Wait, you have it set at 10? BTDC while installing the distributor? When installing the dizzy, you're timing marks should be set at 0?, with the engine at TDC on the compression stroke. When you set your ignition timing, you will then rotate the dizzy until you're firing at 10? BTDC.
As FRISBEE said, don't forget to put the jumper wire in when you set the ignition timing
ok thanx, ill do that, since i just took the distibuter out and the never touched then cams everything is timed except the distibuter
