Originally Posted by matt1993supraTT
still running the stock ECU man this car has got the bugs or somthin, as of right now the block being bored .20 over the roating assemble is getting balanced (wisco pistons eagle rods AC bearings) so if i see a sensor that even looks like it might be messed up then ill replace it this thing has been broke to long!
I don't know if I'm not getting the complete story here or what, but the approach to finding the problem doesn't make a lot of sense. From your description it seems like the answer to an rpm limit problem was to bore the block and rebuild the bottom end. In truth, even a piston with a very low compression/leakdown won't limit your rpm. What were the compression/leakdown numbers before you all decided to tear down the shortblock? And again, was the ecu showing any codes?
At the very least, I'd ask that you don't tell anyone that we said you should rebuild the engine because of an rpm problem - because we didn't!
Thanks in advance...
