Old 05-21-2010, 04:38 AM   #2
batmmannn
batmmannn's Avatar
Default Bhg
No I don't agree with your mechanic. If you can turn a wrench you can replace your own head gasket and fix the the leaks yourself. Many people do and there is plenty of help here to do it. If your motor has compression and ran good, pull the head and replace the gasket. These cars usually leak from the valve cover gaskets and the front crank seal. You can do these repairs with regular tools and tools that Auto Zone will lend you with a deposit. You can do the whole job for cheap. Even if you took your head to a machine shop for new valves seals or to have checked out you still would be under $200 to do it right.
You could probably find a good mechanic to do it for you for about $500 if you can catch him away from his shop rates. Remember this economy is bad and many guys can handle this job. It;s not really that bad. Guys on this forum have done it with little mechanical experience.
Supra motors are known to go over $250,000 miles. I just stopped and looked at one for sale on the side of the road. It had over 260,000 miles and ran good.
