Old 05-21-2010, 03:19 PM   #41
matt1993supraTT
matt1993supraTT's Avatar
matt1993supraTT is on a distinguished road
To start with I did a pressure test and found that the head gasket was blown then did a compression test and found that all the cylinders were down. After we pulled the head it was obvious you could see the four marks in the cylinder made from the piston skirt had been walking up and down the cylinder. The machine shop said it had to be bored. Here it is the whole story.
matt1993supraTT is offline   Reply With Quote
