Originally Posted by kadinz
guess what?
cars gotta knock...
guess what?
im going to beat the fuck out of someone if i dont get a refund.
just drop the oil pan and replace the rod bearings there like 35 bucks at discount auto should take about 3 hours in a driveway just buy oil a filter bearings oil pan gasket and have a good torque wrench
it should cost a total of about 100 bucks at the absolute most and you'll have an engine that you know the rod bearings are good for a long time if you do the job correctly
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
