Originally Posted by batmmannn
Hey guys I got two crank seals in my felpro kit but only removed one the large one from the crank behind the timing gear pulley. Where does this other smaller one go? Am I missing something on my timing cover that this is supposed to be housed in? I don't see how it could anywhere unless the smaller seal is housed behind larger seal on the crank somewhere. Please respond. I can't locate the seal in book either, Could the other be the rear crank seal? Thanks, Scott
your rear main is bigger than your front crank seal are you sure it didnt come with cam seals?
92 miata 7mgte swap  forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
