Hi,
Are you saying the connectors on the harness differ between an auto and manual setup in term of sensors?
but then you're saying the connector that connects to the ECU is identical, regardless if it's an automatic or manual engine harness, correct?
So for example if I have an automatic engine (with an automatic engine harness lets say), and if I were to connect a manual ECU it would fit the connector on that harness?
Sorry for asking so many questions. i just need some clarification that's all. Thanx
