Almost there!!!!
Well guys I am almost road worthy just did a ton of work on my car I replaced radiator,center bearing on the drive shaft,put on a fan shroud and a new clutch also putting in msd ignition box and a map ecu 2 qh also replaced rear speed sensor and rear transmission seal I am lucky to have a neighbor next door that is a mechanic he helped me put it all in and only had to buy the parts WOO HOO!!!
1991 Supra turbo t-61 turbo 550inj high volume fuel pump cold air intake HKS blow off valve need to ge t it tuned not sure what else it has on it.
