Thread: engine problems
Old 05-29-2010, 10:08 PM   #1
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
If you are talking about the temperatrue sensors around the thermostat housing, you can use or move your old ones. Use a small amount of teflon paste or thin tape. Don't over tighten. Its easy to crack the aluminum here. Even the rear thermostat housing itself unbolts from the block. You will need a new gasket or silicone.
