If you're sticking with the same engine (like 7MGTE for 7MGTE) and swap all of the components over from your US engine onto a JDM engine, you can run your US ecu. The engine mechanicals are all the same, JDM engines just have different smog controls, which is why if you didn't swap it all over you would need the ecu.
Keep in mind that there are some differences between engines before 1989 and engines after 89. Easiest way to tell what year the one you get is to compare the oil pan from yours and the JDM one.
