Old 09-06-2005, 05:31 AM   #2
rnoswal
rnoswal's Avatar
It probably is the splash shield under the car. It may have already been broken in half. On mine it is a long, one piece of plastic that bolts on under the car, from the front air dam to just under the engine crank pulley. Maybe some of the others came in two pieces. I also built a sheet metal shroud for the part that goes from the air dam to just under the radiator. It is needed I think for cooling purposes. It also catches tools and nuts and bolts while working on the car....;-).
Russ
