Originally Posted by dannys35
Also something not good is happening after driving the car for a while after it heats up it starts bucking like a bronco in a rodeo at lower RPMS. I have no idea what it could be also I am feeling a lot of heat coming from my gear shifter in the car is it over heating and maybe the temp gauge is not working can any one tell me what could be causing these problems the car has a R154 transmission in it I just replaced the clutch and flywheel so that should not be causing the problems .I am at my whits end somebody help please
check your tranny fluid mabey its leaking from bad seal
