when you set your timing did you tighten the dist bolt alot i had another one doing the same thing today at work making the same noise as soon as i loosened the dist bolt it went away it was loose when he came in so i shimmed the dist with a very thin washer and the noise is gone ill try and post some pics or a vid tomorrow to show you exactly what i mean
92 miata 7mgte swap  forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
