not sure on the brand but i did my exhaust today also it looks pretty good but turned out at mor of an angle than i thought it would im running full 3 inch straight tube from the y pipe back i cut out the 2 inch connected to the y and went from there to right behind my rear end with 100% straight stainless then 1 30 degree bend to my muffler i have a total of 8.5 feet of exhaust from my y pipe back lol it sounds pretty mean and going to the 3 got rid of the "rice" raspy sound
but yeah ill post pics up and i really doubt its your valve spring if you want you could call tomorrow or something and ill tighten and loosen my dist and see if thats the same noise you have
92 miata 7mgte swap  forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
