It's pre89. 89 and newer didn't have headlight washers. He's done a lot to create a 89 plus white package MKIII.... no necessarily a bad thing, shows attention to detail. One of the big tell tale signs of the job having been done COMPLETELY right is if ALL of the mounting bolt holes in the upper face inside the mouth of the bumper cover actually have bolts in them... they're not in the same locations on the pre89 as they are on the 89+ so either custom brackets need to be made or half the holes are left empty or new holes are dripped and self tapping fasteners are generally used. I don't see any sagging between the nose and the bridge from the lower bumper cover which indicates they most likely did at least swap out the nose support member.
Oh, and it's still on the stock springs and thus great for off road driving!
