Originally Posted by cre
Which flywheel you run depends on the transmission, not the year... same for the clutch
Correct me if I'm wrong, but weren't the pre89 7M's balanced externally and therefore required the flywheel to balance them, whereas the 89+ 7M's were balanced internally and had a neutrally balanced flywheel?
