On my 7MGE that part is the Idle Speed Control Valve. If that is what you have there and it sure looks like it, You can't run the engine without it. I controls Idle when the A/C is on and probably the cold start idle too. But since your engine is different, I may be wrong. Hopefully others with that engine will reply.
Russ
