Old 06-06-2010, 02:15 PM   #17
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
Originally Posted by batmmannn View Post
Always a challenge when a gremlin gets in your car. Could be as simple as bad connection to the battery terminals, though not likely I am sure you already checked that.
I have wired a $5 AutoZone relay in parallel with it (separate switch), and that one works every time.
The stock silver relay box says "ECT" near the top.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
