Old 06-08-2010, 02:56 AM   #1
turbonicsperformance
turbonicsperformance is on a distinguished road
Originally Posted by javier medrano View Post
i have been trying to improve my torque on my 88 supra but i dony know what to put so it can have a higher torque so does anyone know what i can do?
try a few different setting with your cams get a set of adjustable cam gears set your ignition timing a little advanced though not much make sure you have a good working cooling system try an electric fan and a cold air intake a set of headers if your actually looking to build the engine you could do high comp pistons lightened flywheel and one piece shaft none is cheap but it all helps
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
