Thread: Misfireing 7m
Old 09-07-2005, 09:01 PM   #3
suprafreak90
suprafreak90 is on a distinguished road
Unhappy
if the wastegate is stuck open you probally wont get anymore than 5or 7psi out of a stock ct26 but u should still feel some boost.RE: missing check the all the plugs and wires when the valve cover gaskets go in the 7mgte they leak oil all over the plugs . sorry i couldn't be of more help....wouldn't worry about the white smoke you just did a swap so its been sitting awhile building condensation through out the exhaust it will probally smoke for about a week after you get it running right and burn all that $hit out.
suprafreak90 is offline   Reply With Quote
