The metal clip (it looks like a paperclip) goes on the outside of the TPS connector. There's a little groove cut in the connector towards the end of it (furthest from the wires) that is slips onto, which helps lock it in place on the TPS. Without it, the connector can vibrate loose giving the ECU intermittent readings from the TPS.
