Originally Posted by james089
the car seems to have good air/fuel when its idelling, but under load it leans out to around 16. Just installed a new aeromotive FPR, but the car still leans out. Any ideas? fuel pressure is set to 55psi. Help!
few questions are you turbo? if so what mods do you have done? also what wideband are you getting your numbers from some of them have a adjustment it may be off. but if you are turbo and your going to 16 on a fully functioning uego then DO NOT drive until this is fixed you'll end up causing major damage
92 miata 7mgte swap  forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
