hi guys. well as luck would have it the 90 degree hose went out. when purchasing a new one you have really only 2 choices. 1, order the exact part from toyota or 2, find one at your local auto part stores with the exact same bend radius.. ( you need that!) I went and got one just by eyeball and didn't fit. I had to end my work on that note due to the time. now today its raining outside, (nice) so I have to wait for the rain to stop in order to proceed.
in order to get to the 90 degree ( #5 water bypass hose) you pretty much have to strip your car down to valve covers. so while your there give it a tune up, new valve cover gaskets (if needed) and inspect the condition of your #3 valve cover gasket. if in need of repair see.
http://www.toyota-supra.info/forums/...ark-plugs.html
as it turns out I have a foot of oil in my last 2 spark plug gallery. (BAH) so going to replace those seals on the allen head bolts today (napa ordered 25 oil drain plugs just for my order last night) just a question tho, are you able just to unscrew those 14mm allen head bolts directly from the #3 valve cover or is there other things I need to take off. like the rest of the valve covers ( you only need to remove the LEFT valve cover in order to repair the 90 degree hose)
I bought a valve cover gasket cause i figured i would just change them since i was down there.
my #3 valve cover was broken and chipping.. im afraid one of the chips fell down into the valve cover.. (oh noes) im screwed. anyhow Ill take some pictures from my camera phone once i start to re assemble.
oh and I found tons of oil in my accordion hose ( turbo leaking oil, time for a new one) and in my intake hoses.
heres the link for the components page for the tsrm
http://www.cygnusx1.net/Supra/Librar...aspx?S=EM&P=32
just waiting on the rain to stop. I need to go to work tomorrow and I don't have a car (
) all i have to do is put on the hose. and re install the parts taken off. heres hoping the rain stops soon..
