Cruise Control
I did a search and didn't turn up anything relevent on Cruise Control problems.
I have everything on my car working now except the cruise control and the drivers door lock switch.
The cruise control switch on the dash lights up when pressed but when I try to set it on the steering wheel it just does nothing.
Are there any common failures known about these units? I am posting this a bit premature I suppose cause I have not even checked the fuse if there is one but since the switch lights up I am thinking the fuse is probably OK.
Thanks, Scott
