The cruise control itself is vacuum operated. There should be a vacuum line(after the throttle plate) that connects the speed control actuator and I believe the heater control valve vacuum lines together. Make sure that vacuum line is there and in good shape. The other common failure point is the rubber boot for the speed control actuator cable will deteriorate, causing it to not move properly/not have enough tension in the cable.
