Thanks Guys
AHHHHH! I had just filled my brake reservoir yesterday or so. Maybe that is why it did not work before.
HEY
My Car just found another gear!!!
I took my right front brakes apart and sprayed the caliper down with PB Blaster. My right caliper was sticking and dragging the right front wheel. The car gained a boost of power after I did this. So far they are releasing OK. Gotta Love Blaster!
Thanks for the tips guys, as I learn more I will answer more posts... My car is really doing OK, I just put a new radiator cap on with a pressure valve.
I think my old cap was releasing too soon allowing radiator fluid to overflow the tank. We will see.... I am losing coolant fluid somewhere..... I hope it stops now.
The car is getting significantly faster, is it possible the rings are seating better and my compression is going up?
Thanks, Scott
