Old 06-12-2010, 11:01 PM   #1
batmmannn
batmmannn's Avatar
Default Where is the fan relay on an na supra?
I have searched posts all forums on locating the fan relay on an 88 Supra NA
I ordered one from Toyota. I read a British post that said it is under the fuse box under the hood. Fine, I took all that apart and found 2 relays that appear not to be replaceable unless you bend back some stubby metal tabs . Attached is a pic.
Are either of these the fan relay and how are you supposed to replace them? They don't unplug and do not appear to be removable from the bracket. Not sure if either of these are the fan relay. These look more like headlight relays to me.
OK I found an illustration, would the location of the the first fan relay be my fan relay for a non turbo?
Help if you can thanks, Scott
ID:	3141   Click image for larger version
