06-14-2010, 04:21 AM
#40
Originally Posted by slideways-2jz
Yes the KA is a good platform, and it CAN make alot of power but not without alot of things adressed. An sr make 205 crank HP not WHEEL hp. At 7 psi, a stock KA at 7 psi will make around 230-250 hp with upgraded fuel pump, injectors, arp head studs, multi-layer head gasket, and a decent tune. If your aiming for 500 hp on a KA it will have to be very well prepared an you will be spending much more than it would cost than a SR swap, but it would be worth the extra money! Lol just my 2 cents, having owned 6 240sx's, all KA, 2 were KA-T. And i'm in the process of building a nasty KA-T w/ holset hx-35 turbo
we had a kid come in he had a turbo kit off ebay some injectors and a safc2 he made 230whp stock headbolts gasket bottom end everything with 100k on it and a volvo turbo off an old wagon lol it was a haggard mess but youcant deny power like that
92 miata 7mgte swap  forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
