ahhhhhh!!! fire
so today on my way to trade in my car i threw a rod straight through my block and that caused my car to catch on fire... also watch your speedo cables if they fall out of the clips they rest on the exhaust manifold mine caught fire causing my coolant line to get a hole in it then overheat and explode
92 miata 7mgte swap  forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
