Originally Posted by dlfred
I have search the threads and with no success in tracking down a driveshaft center support bearing. Unfortunately cost is an issue. I appreciate any help. Thanks
There is really no other way to go about the replacing the center support bearing....you have the following options:
1. Buy OEM from Toyota, yes.....it will cost you.
2. Buy from Napa or Auto parts store....you will need to modify it to fit.
3. Lastly, you can get a 1 piece steel or aluminum driveshaft....it will cost almost the same as a replacement center bearing support, just a few dollars more. Then you don't have to worry about the center support bearing.
