Coolant flow NOT THERE
Hey guys I need some help here, if you start your car cold and take of the rad cap off and look into the filler neck you can see the coolant flowing right? I mean you can see it flowing no problem right? Mine? No flow or minimal.
Water pump does not leak, no leaks can be found but I am overheating. Your best guess, do you think it would be a bad water pump with eaten up fins? Or do you think the radiator is blocked? Any other choices?
Car sat 7 years. Best guess?????
