89 bucks
Did that Cre finally got the parts number from the guy at Toyota, $89 bucks for both relays riveted to the assembly the other is an AC relay. It's like Utz potato Chips, you can't just have one. I swapped out the assembly from my Black Supra but that made no change. I jumped the coolant temp switch and still a no go. No Luck finding replacements from 3rd party vendors, checked Auto Zone, Carquest, Napa Looks like I have to wire in a direct switch. Looking for the best location to run wires from the engine bay into the cab. Can't find a hole. Where do you guys squeeze through? I have solved my overheating problem though. Is the fan temp switch the one on the top of the thermostat housing or on the side. I might have jumped the wrong one. I jumped the one on top. I need to check that. Fan runs great hooked directly to power and ground. Thanks
