To add to pwpanas, if the motor has a 100k on it, its going to be that much harder getting 500 hp out of it, and does that have a w58 or r154? that tranny isnt going to hold 500 hp especially if its a w58, in not sure on the r154 but i doubt thats going to handle to many pulls on 500 hp. Trust me on this one listen to pwpanas, he probably has the most extensive knowledge about mkiv on this forum, but if you wanna spend the money blow the engine, you can then swap the 2jzgte and might as well get the v160 while your at it. You can get the turbo kit and at least get probably 350 maybe 400 hp and use the tranny you have. Good luck
