Originally Posted by btwilson86
Nope. Your turbo isn't spinning fast enough at idle to counteract the vacuum that your engine creates, so you should be reading a few in/Hg (or -psi depending on your boost gauge) at idle.
see, the thing is...its still -20 psi. same as before the install....is that normal or even ok?
