your going to need:
-5sped tranny (w58 or r154)
-clutch pedal
-clutch (entire clutch flywheel all that goes with)
-your going to need to jump the parking gear/ or the car will never start
-Clutch Master and Release cylinders!!!(needs the hardline that goes from master to release)
-possibly the cross member that goes under transmission
-break pedal assembly from a standard unless you want it in the way of the clutch!
-Pilot bearing and throw out bearings would be great time to replace!
-possibly a 5speed starter!!!
good luck should take you a while to find these parts!
0oh and your cruise control may not work after from jumping with the n/p switch!!!!
i have a w58 tranny up for sale! but im too lazy to ship it anywhere sry...
