Remove the stops (the white knobs), remove the weather stripping from the outside edge and then jump the window regulator motor with a battery or or other 12v supply which can provide a decent amount of current for a few seconds.
NOTE: Removing the metal bracket which the rear view mirror mounts to can make the job VERY easy.
This really belongs in the MKIII section... thread moved.
