Old 06-23-2010, 07:00 AM   #10
batmmannn
batmmannn's Avatar
Default Your Machine
Your tape was most likely eaten by the cassette player. This happens because the tape heads and rollers are sticky or dirty. While you are in there, clean the rollers and the tape head throughly with a Q-tip and rubbing alcohol. This should help. Oh wait that must be a transport problem because there is no tape with that adapter. Get one of those FM Ipod adapters that transmit your music to the FM radio there is no reason to be using that cassete deck at all unless you have cassettes that you want to listen to but I doubt that you would have any. Mine also has the stock radio, there are collectors looking for that radio, you could probably get enough for it on ebay to buy yourself a nice new aftermarket radio with CD player. Bezel Adapters for installing new radios are also on ebay. If its a transport problem I doubt you could find anyone that could fix it. Seems like the more you mess with those the worse they get
