Starting Issue
Usually in the morning my car starts after several cranks then if shut it off and restart it within several minutes it starts fine, but if I wait for like 20-30 minutes it takes several cranks..It does burn some oil..so would it be that the valve stem seals are deteriorated and is leaking oil into the combustion chamber causing the problem?? Also any tips adjusting TPS relative to distributor timing? Any help is greatly appreciated.
 Supe supe!
1986.5 Supra Manual Red Mica(Maroon) w/wing: Custom sound system, 18" Tork Revos, smoked tail lights, markers, and turn signals.
Mods: Eibach lowering springs, Energy poly front upper and lower control arm bushings, custom cold air intake, solid engine mounts, Magnaflow, short shifter, Optima Red Top, other custom fabrications..and yes a bra.
Reason: Revamp
