Originally Posted by usa203
I bought an 861/2 Supra and previous owner said trunk lock not working. I went to toyota and was told Supra was a one key set-up. So I thought I would pull the trunk cylinder and have it replaced or re-keyed. After removing all the plastic molding, I still do not have access to cylinder. Suggstions please.
IIRC the exterior panel has to be removed (just a few nuts on the inside to pull it) to access the cylinder... it's been a long time since I've pulled one, but it was pretty easy... They're also cake to rebuild if the cylinder itself and housing aren't too worn down.
