Originally Posted by CanadianBak'inSupra
your radiator is more than likely fine. a good flush would be the best option.
also change out your thermostat and check your fan shroud and fan.
check for error codes...
you're right the radiator is probably fine but the drain cock has been 'removed' somehow, making flushing seemingly messy ordeal as i'll now have to pull off bottom use to empty the thing.
fan and shroud are okay.
thanks for all the advice.
