You can use your VIN plate located on the firewall to tell you the color code and then just search online to find out what exact color that code is. Here is a link with a diagram showing what numbers mean what.
http://www.4crawler.com/4x4/ToyVIN.shtml
1987 Supra "TheHondaKiller"
K&N FIPK Intake, Greddy Turndown, Cat-delete test pipe, Unorthodox crank pulley, HKS SSQ Blow Off Valve, Goodridge Steel Braided Brake Lines, Powerslot Slotted Rotors, Front and Rear Strut Bars
