Thread: Starting Issues
Old 07-01-2010, 02:18 AM   #10
SuperSpartan
SuperSpartan's Avatar
SuperSpartan is on a distinguished road
Originally Posted by fullthrottlesrqsupra View Post
looking at the engine from the front of the car its on the drivers side in the fuse box it is all the way on the left (4th on the top to the left) its marked as "ALT 1.25b" when you look at it it should make a u shape replacing a fuse basically you would check it the same way as a fuse check both sides of it with the car off hell it might fall apart when you touch it like mine did it looked perfect but as soon as i touched it it cracked in half if it is bad you need to pull out that section of the fuse box and the fusible link is bolted into the box if you still need more help i can post pics later
hah yea a pic would be nice, cause when i look at my car all i see is a mess
1990 Toyota Supra Turbo!!
www.cardomain.com/ride/3067504
SuperSpartan is offline   Reply With Quote
