A/c
Did my first AC evac and charge today. Went OK. My Ac is working. Should be interesting to see how long it lasts.
When I took off my compressor it had no oil. It was seized. Should I have assumed that the entire system would be dry or near dry of oil. I put about 4 ozs in the drier and the 4 in the compressor. I didn't want to go more in case there was a few ozs still in the condensor, lines and other parts of the system. Being that the compressor was bone dry should I have gone a full 10 ozs? My $9.99 AC compressor off ebay is working just fine and apparently not leaking.
Sight glass is not clear even after 3 cans of refrigerant. When the clutch disengages I see foam, when it reingages and is running I got a bubble or two about 180 psi on the high side and about 34 on the low side.
I did evacuate it down to -29psi and the vacuum held fine for like an hour and a half before I went forward and charged it. What do you guys think?
I didn't want to flush it. Besides I figured I would do this one and test for leaks. I used the same oil and refrigerant it had in it before I started on it. Put on a new drier, but man getting that thing bolted back in was a pain in the ass!
What were your results? Should I have added more oil or less?
Thanks
