Old 07-04-2010, 04:18 PM   #2
Supra_Freak_7m
Supra_Freak_7m's Avatar
Supra_Freak_7m is on a distinguished road
When you had the engine rebuilt, Which head gasket did you use? Did any material get taken off of the head? Which Fasteners did you use? ( I.e. ARP Bolds, Studs or factory ) Water pump get replaced at rebuild time? Thermostat? What is your ignition timing set at? Did you jump the proper terminals before you set the ignition timing? Cam/Crank timing set perfectly? Are you following the proper engine rebuild/break-in oil change interval?
Check these things and if you have any questions about what i listed here, feel free to ask....
1987 Toyota Supra 7MGTE AUTO
1987 Toyota Supra 7MGE MANUAL
1990 Toyota Supra 7MGTE AUTO-> MANUAL
Supra_Freak_7m is offline   Reply With Quote
