doing a 7mgte swap, have a few questions
what would be the best oil to break my engine in the firt 500 miles? next 2000 miles? how much transmission fluid do I need? what would be the best kind?
Im not going to be using the egr system, what do I do with the vsv and vaccuum lines that go under the intake to the p.s. pump? Also will it mess with the ECU?
And last the wiring harness, I notice there are a set of plugs that go under the intake side inbetween the intake manifold where do they go? I couldn't find any ports to plug them in. ill post pics of the plugs in a bit.
Thanks for your inputs.
