Might as well pull it
If you have it that far you might as well just pull it. I have seen pics of them pulled with radiator removed and the trans still attached. Do the rear main crank seal and clutch plate while you are there. Can you throw some pics up so we can see your progress?
http://www.toyota-supra.info/forums/...n-leaking.html
