Old 07-05-2010, 11:13 PM   #18
907mge
907mge's Avatar
Well have you ever stoped to think of how much 3 quarts of oil is? Some cars only use that much for a whole oil change. My mom's subaru uses oil like crazy and never appears to have a leak of appear to burn it either. And as far as the dash cluster goes, it took less than a hour for me to get it out the first time. You just need a few simple tools and time. The only problem I ran into was that the physical size of the bulb changed, the bulb number is the same but the bulb is slightly bigger so a dremel is in order.
