Originally Posted by I h8 Hondas
Btw: As I was leaving the town I was visiting I had to pull out onto a busy highway and while looking carefully side-to-side I absentmindedly put it into third gear instead of first and somehow managed to not stall it. The bottom end didn't like this. I'm wondering if this mistake could have done my engine in.
Unlikely.... and if it did then whatever broke was a day away from the grave anyway.
Your pressure is fine, but the range is a bit wider than common... what weight oil are you running?
